| | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | I am in the process of building a 1939 chevy truck. I read all the post I could find concerning the t5 transmission modification. The difference from AD to art deco trucks is the bellhousing. For 37 thru 46 the Ebrake and master cylinder are attached to the bellhousing, after some research I found a company called vintage metalworks out of Ohio who makes the correct spacer for these applications. I went ahead and ordered two.with this I can install the 235 s10 t5 transmission and I haven't figured out the rear end yet.ill keep you posted on the outcome.can anyone suggest a good rear end that will work for this truck and that comes with disc brakes? Also is there a disc brake conversion for the front to keep it 6 lug? I want to run 17"artillery rims. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Dave Farwell at Vintage Metalworks is a good guy. Very helpful. Can't comment in the other questions.
What fifth gear ratio does your T5 have? Matching the rear diff to your 5th gear is pretty important for driveability. Otherwise you might bog the engine on hills. | | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | How do I figure out the 5th gear ratio?
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | You can look up the gearing using the metal tag number. It will read 1352-### This website offers fairly accurate decoding, but the year does not always match. I have found errors, so I recommend checking it yourself using the methods I outline below. My website shows you how to be sure without a doubt. The gears don't lie! Link = http://lugnutz65chevystepside.weebly.com/how-to-determine-the-t5-gearing.htmlJay
