3 members (Otto Skorzeny, dt235sd, 2-Ton), 58 guests, and 2 robots.
Topics128,049
Posts1,055,661
#1067725 11/11/2014 4:04 PM
does anyone know where to get bushings, and/or what is the prescribed method for removing the old ones. I have a couple of ideas, but it if there is some actual time proven method I wouldn't argue with that.
What bushings are you asking about?
216/235's do not have bushings in the housing for the shaft originally.
My Blog
the one I have apart has a bronze bushing in the upper half, but the top where the distributor shaft rides is worn.
If the shaft is worn it needs to be replaced. It can not be turned down as the shaft OD also needs to fit the pilot hole in the oil pump.
Rebuilders must have a supply of bushings but you may need to make your own.
My Blog
