| | | Forums66 Topics128,162 Posts1,056,910 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Can anyone tell me the stock location for the horns on a 1954 PU?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Depends on what ton the truck is. 54 shop manual Horns | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | The original horn is bolted to the radiator support on the drivers side., It is located behind the center horizontal grille bar. Two holes drilled at the factory. > Click here for Horn Installation in WSM. Hookup to wiring terminal also shown. You may need to hold Ctnl key and tap the "plus" key to enlarge. > Click here for a diagram from the 1954 Chevrolet Accessories Installation Manual. It shows the original horn on the drivers side. The horns on the passenger side are the optional accessory high note horns. Only one accessory horn is used on the passenger side. Two horns are shown because the accessory horn is located differently for pickups and for big trucks. The top horn is the location for 4000-6000 Series trucks. The bottom accessory horn is the location for 3000 Series trucks. It's been a while since I visited Stove Bolt. Best forum on the web. I'm still dumping time and money into my '55 MG TF-1500. The truck doesn't require anything but an occational wash job. Still haven't tried to sell it. > Garage BuddiesLonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
