6 members (Wickedbass, JW51, MRMEROTH11, GradyB, SWEET, 1 invisible), 63 guests, and 2 robots.
Topics128,066
Posts1,055,873
Members48,428
#1067450 11/10/2014 2:54 AM
Q
Q Offline
Hi, I have a 1949 1/2 ton. It came with a 3 speed but the PO removed the column shift. I really want a floor shift so I found a sm 420 but the output shaft doesn't match up. I think it may have been off of a 1 ton. Does anyone have any ideas of how I can get this to hook up to the torque tube? Thanks, this Site is so helpful.
You need the rear cover/housing from an SM420 that was used with a torque-tube (1948-1954). It will replace the open-rear cover on later SM420s.
Q
Q Offline
It does have the cover. I think I need the yoke that bolts to the universal joint and has the speedo drive gear.
