| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 31 | I have a 37 1/2 ton that I recently got on the road after a full tear down. Working the bugs out. I had an issue with the pressure plate that was not adjusted properly and had a wobble. Fixed that. Everything is smooth now except the shifter shakes. Maybe I am used to modern shifters. Is there any concern with the shifter moderately shaking and moving side to side? Should I be concerned?
Mike J 37 GMC
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It could be a drive line issue causing the shake | | |
