4 members (Guitplayer, MickeyP, Ponchogl, ShopRag), 90 guests, and 1 robot.
Topics128,035
Posts1,055,564
#1067005 11/07/2014 1:58 PM
I have a 37 1/2 ton that I recently got on the road after a full tear down. Working the bugs out. I had an issue with the pressure plate that was not adjusted properly and had a wobble. Fixed that. Everything is smooth now except the shifter shakes. Maybe I am used to modern shifters. Is there any concern with the shifter moderately shaking and moving side to side? Should I be concerned?
Mike J 37 GMC
It could be a drive line issue causing the shake
