| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | I am looking for some help on where to hook up the dash mounted throttle cable to my 1961 chevy 235 single barrel carb. I have the square block with the small screw in it for the choke cable, but cannot find a place to hook up the throttle cable. Any help would be appreciated. Photos would be better.
Thanks, Paul up in Alberta, Canada | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | Hello, so the throttle cable connects to the foot peddle linkage then and not the carb itself?
Paul | | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | Hello, so the throttle cable connects to the foot peddle linkage then and not the carb itself?
Paul | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes Paully, the cable hooks to the linkage, with a 'slip' fitting so the linkage can still throttle the carb higher
Bill | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | a factory assembly manual is a plus for working on these trucks | | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | Would you by chance have a picture of the slip fitting. Thanks, Paully | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the cable end goes thru the linkage rod in place of a cotter pin, with the block on the end of it being the 'pull' .... need to track down bolter 'cmayna', who posted pics of the setup some time back .... also requires a special bracket on the corner of the carb like this that captures both the choke and throttle cable sheaths Bill | | |
