| | | Forums66 Topics128,162 Posts1,056,951 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | I just got this in the 1/2 inch drive. Needed to replace my old one cause it would give very different readings from time to time. I have used the spring bar for years but it requires you to take your eyes off to see the scale, and that scale is getting harder to see. Clicker is simple and safe for me and my 2 handed approach. One on the shaft and one on the handle. So I look for length in the handle. It was on sale, and works well.
Steve H
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | HF Torque wrenches best deal out there. The locking know at the bottom is unique to them... but they are rated highly: Carcraft magazine: http://blog.harborfreight.com/car-craft-reviews-torque-wrench/“… we also tested Harbor Freight’s 1/2-inch clicker torque wrench, and it was also very close. It also has a range of 20 to 150 lb-ft and a lifetime warranty. Accuracy after five consecutive tests at 70 lb-ft ranged from 68.8 lb-ft (-1.2) to 70.3 (+0.3), with an average error of 0.30 ft-lb over five tests. It doesn’t get much better than that for a mechanical torque wrench.” Not releasing the preload will kill ANY torque wrench. Always set it back to ZERO when done.
