0 members (), 97 guests, and 1 robot.
Topics128,128
Posts1,056,358
Members48,441
#1066338 11/03/2014 10:22 PM
Were the 3 speed transmissions in these all syncornized. I need a 3 speed for my truck and I have access to one and it would be nice if it was.
I'm wanting it for my 58 GMC. Larry
58 gmc 100 with 350 sbc
Yes, If it is the stock 3 speed transmission it is full Syncro.
It can be identified by the 7 bolt side cover. It also has a fine spline output shaft. You will need to modify the shift arms and find a fine spline yoke to use it in your 58.
Fred
Thanks. I picked it up this morning. It's going to make a great addition to my 58. I'll also have to source the speedo hook up. It came with an extra starter and the bell housing which I don't need, plus the clutch lever and a clutch and pressure plate.Larry
One reason I got rid of my 1965 3 speed was because it wasn't synchronized in 1st gear. I recently bought a 1969 3 speed for the floor shift linkage. Is my 1969 3 speed synchronized? What year did they start synchronizing 1st gear?
Riding in the Passing Lane
67 was the first year for the full syncro 3 speed.
1972 Chevy c10 Cheyenne Super
