| | | Forums66 Topics128,169 Posts1,057,043 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | I am looking for someone who can Rebuild 1929 Rocker Arms Properly as I Need to have the Rocker Arms on my 1929 Chevrolet 194 Rebuilt. They need to be Welded up, then ground & shaped PROPERLY. Possible hardened as well. Would like someone who is experienced and will provide a QUALITY end result that will last me a LONG time. Any leads would be appreciated. I talked with Bill (Billy Possum) over @ C&P Automotive, they no longer provide there Rocker Arm Rebuild Service as they are unable to find anyone locally that can rebuild the Rocker Arms with Quality Results.Once I can find someone to do this service I will have my Rocker Arm Assemblies Rebuilt w/ New Shafts, Bushings, Springs, Clips, Wicks. From what i can see the Valve Adjustment Screws & Locking Nuts are in great shape, they all move freely and are NOT marred up. If the Rocker Arm Place can do this would like to have it all done in one shot so the bearings can be reamed to fit the shafts properly. I will be getting the parts from Bill, or one of his outlets  Need to debate if I want to PULL the Head and have the valves check and maybe the seats cleaned and filed for proper valve seating. and also look at new Spring Caps & Keys. Maybe NEW Valve Springs as well. Also will put in NEW Valve Push Rods & Push Rod Ends as what I have now is a mixed bag of the original 2 piece and some later one piece rods. Also what about replacing the Valve Tappets ?? any way to determine if the ONE I have are worth keeping or need replacing ?? 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Have you talked to Skip Gear with the VCCA? He is very knowledgable about the early Chevrolet 6 cylinders. Mike B  | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Yes I have
we talked about Bill, as he is THE MAN, but as you see he no longer does this. also going to contact The Filling Station to see what they offer and can do for me.
just weighing my options. 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | OK, sorry for the delay, finally got around to taking some photos of the Rebuilt Rocker Arms. Let me say they Look Fantastic and like NEW. I did opt to get all new hardware (Springs, Clips, etc...) Tips were ground, built up, then contoured. Bores were reamed, bushed, then reamed to fit coated shafts. Shafts were coated, then ground down. Stanchions were also reamed to fit new shafts. Very Happy, can not wait to test them out... Rocker Arms 1Rocker Arms 2Rocker Arms UndersideRocker Arms EndRocker Arms End Clip & SpringRocker Arms TipsRocker Arms Shaft & Spring 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | who did the rebuild, and how do you determine if they need to be rebuilt? | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I took my rockers to Larrowe and sons, in Sandy Oregon, However now I think it is the sons now, but whatever the case a very nice job was done, and was very reasonably priced. (don't remember the cost, but I do remember it wasn't that much) And the way to determine if they need rebuilt is to diassemble and look at them, if you can't tell, then probably they don't. In my case it looked like they had lost oil supply for about 2 years. There was no mistaking the carnage. But as a testament to these old engines, it looked like the oil line had broken at some point in its life, and was simply replaced. I ran it like that for about 20 years.
