5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#1065841 11/01/2014 2:21 PM
I have a 1949 3600 pickup, original 6 cylinder, has been converted to 12 volts before I bought it. Installed new battery, positive cable got hot and terminal burned off cable. Positive/negative connections are correct. Engine did not turn over and starter did not engage. I am thinking that the starter is bad or maybe solenoid or foot starter switch? Any suggestions? Thanks
Don19655 #1065988 11/02/2014 3:15 AM
5 Online: Content
Apply 12 volts from a battery charger directly to the positive post on the starter and a good ground and push down on the starter switch on the starter. Starter should spin without engaging the flywheel (since you aren't stepping on the stomp starter). If the starter spins, you may have a bad battery cable (internal corrosion).
Carl
Don19655 #1065998 11/02/2014 3:35 AM
If the cable got hot enough to burn when you installed a new battery you have a big short to ground somewhere.
If it did it when you hit the starter button that's another story.
Don19655 #1066004 11/02/2014 3:45 AM
Thanks. I will try your suggestions and post results.
Don19655 #1066064 11/02/2014 2:16 PM
I had that happen on an 85 Toyota P/U I drove as a kid. Melted 2 batteries before we figured it might be the starter. It was pulling almost 300 amps for some reason. Have the starter tested.
Good Luck
36 Chevy 1.5 ton - rusting away
52 Chevy 3100 - in progress
72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
