10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible),
58
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 9 Member | | Member Joined: Oct 2003 Posts: 9 | I am presently working on my first frame up restoration. A 58 fleetside that was purchased new by my grandad. kind of a sentimental rebuild. The step panels, rockers, cab corners and cowls are toast and in need of rebuild. I can find replacement pieces for all but the cowling. I presume they are a d.i.y. project. Any advice, insight etc anyone can give would be very helpful and greatly appreciated. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If the rusted part can be cut out and is suitable for a pattern I could make you one. | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Almost anything can be fabricated by hand. It's time consuming but a complex section can be rebuilt, piece by piece. All you need is some new metal, a cut-off wheel, snips, a MIG welder, project board for making patterns, and lots of patience. Metalman, how would you make a replacement panel that is not normally available with a repro panel? I've spent many hours rebuilding difficult areas like rotted out rear/front windshield openings but if you have a better way, I sure would like to know about it. | | | | | Joined: Oct 2003 Posts: 9 Member | | Member Joined: Oct 2003 Posts: 9 | THANKS FOR THE ADVICE. I'VE HAD LITTLE EXPERIENCE WORKING WITH FORMING OF SHEETMETAL HOWEVER I'M NOT ONE TO WHINCE AT A GOOD CHALLENGE AND CONFIDENT I CAN PULL IT OFF.
CAN ANYONE SUGGGEST A WORTHWHILE BOOK AND OR VIDEO THAT WOULD GET ME HEADED IN THE RIGHT DIRECTION? | | |
