4 members (qside, dunfire, GRNHydra, Rnl364), 93 guests, and 2 robots.
Topics128,064
Posts1,055,859
Members48,428
#106582 10/18/2003 5:22 PM
I am presently working on my first frame up restoration. A 58 fleetside that was purchased new by my grandad. kind of a sentimental rebuild. The step panels, rockers, cab corners and cowls are toast and in need of rebuild. I can find replacement pieces for all but the cowling. I presume they are a d.i.y. project. Any advice, insight etc anyone can give would be very helpful and greatly appreciated.
#106583 10/18/2003 7:49 PM
Anonymous
Unregistered
Anonymous
Unregistered
If the rusted part can be cut out and is suitable for a pattern I could make you one.
#106584 10/20/2003 6:35 PM
Almost anything can be fabricated by hand. It's time consuming but a complex section can be rebuilt, piece by piece. All you need is some new metal, a cut-off wheel, snips, a MIG welder, project board for making patterns, and lots of patience. Metalman, how would you make a replacement panel that is not normally available with a repro panel? I've spent many hours rebuilding difficult areas like rotted out rear/front windshield openings but if you have a better way, I sure would like to know about it.
#106585 10/21/2003 2:16 AM
THANKS FOR THE ADVICE. I'VE HAD LITTLE EXPERIENCE WORKING WITH FORMING OF SHEETMETAL HOWEVER I'M NOT ONE TO WHINCE AT A GOOD CHALLENGE AND CONFIDENT I CAN PULL IT OFF.
CAN ANYONE SUGGGEST A WORTHWHILE BOOK AND OR VIDEO THAT WOULD GET ME HEADED IN THE RIGHT DIRECTION?
