3 members (Rich'sToys, Ponchogl, Peggy M), 332 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#1064544 10/26/2014 3:30 AM
Does anyone make replacement blades for Casco style dash fans?
That's too bad. I've got a nice little Casco fan that works great, but it's only got one blade. I suppose I could make new blades out of something, but I'm partial to original look.
Does anyone know of a material of a similar color, thickness, and flexbility, that could be used to make new blades?
I like it! Thanks Denny smile If I give this a shot I'll let you know how it goes.
Ex Hall Monitor
Ex Hall Monitor
I remember reading some time back about a fellow who made his own blades using thin sheet rubber. I'd think someplace like McMaster-Carr would have suitable rubber.
Ex Hall Monitor
Ex Hall Monitor
The rubber blades on the one I have are flat rubber held in shape by the hub. I'll have to sneak out to the garage and try to find the box it's in to take some pics.
Here you go. Not mine but made the same way. Flat rubber held in shape by the hub.
Ex Hall Monitor
Ex Hall Monitor
I haven't had mine apart so I can't say for sure.
That looks like about the thickness of a cool whip or margarine tub. Or maybe a cheap kids play bucket from the dollar store.
Cut 3 exactly the same size to avoid wobble.
If they need to be molded for a curve, heat them gently in the oven then set them at the curve you need til cool.
Good luck.
Did those actually cool you off, or did it just blow the heat off of the 6 volt motor into you face? Don't get me wrong, I really want one of those now that I saw a picture.
Carl
twotone #1065449 10/30/2014 12:57 PM
My dad ran one in his truck when I was a kid. One day he said "DON'T TOUCH THAT!" so I had to try it out. From then on they could'nt keep me out of it.
I asked him about that old fan and he said it helped a lot in the summer and would defog a windshield fast.
Carl,
How long have you lived in VA?
"In the day", fans were common everywhere in order to give some relief and minimal evaporative drying by pushing air across sweaty parts (unless the humidity was 100%).
I miss those days.
Carl,
I miss those days.
Therein lies the problem,Tim. Our summer air is a fluid, seemingly of a higher viscosity than water. I had a modern fan in a work truck once, but when it was on, it felt like the furnace was on.
Carl
twotone #1065825 11/01/2014 12:59 PM
Ex Hall Monitor
Ex Hall Monitor
Agreed Denny. While I haven't mounted mine I did test it and that's one reason I never mounted it, it doesn't move a lot of air.
Moderated by  ndkid275, Phak1
