| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | How do you removes the tank straps from an under the seat gas tank? The crevices are caked with rotten soybeans so I'm not sure what I'm looks for.
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Hey did Sput get you fixed up on this one? Wrench Fetcher, PhD | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Under the truck. Two 1/2 inch nuts for each strap. If you just remove the front nuts and pull the straps up you can take out the tank. PB Blaster and vise grips you will need.
Trombones Totem Poles And Old Trucks!
