1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1065036 10/28/2014 6:14 PM
1 Offline
How do you removes the tank straps from an under the seat gas tank? The crevices are caked with rotten soybeans so I'm not sure what I'm looks for.
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
U
U Offline
Hey did Sput get you fixed up
on this one?
Wrench Fetcher, PhD
1 Offline
Under the truck. Two 1/2 inch nuts for each strap. If you just remove the front nuts and pull the straps up you can take out the tank. PB Blaster and vise grips you will need.
Trombones Totem Poles And Old Trucks!
1 Offline
I'm all set thank you!
