2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | I know this has come up a lot, but after searching a bit, I still have an unanswered question.
If I had the room, like by moving the master cyl, why not run a conventional style vacuum boosted dual res master cylinder. Provided you could link it to the brake pedal, is there a reason why not? Doesn't it work basically the same way as the hydrovac?
The master of coarse would need to be one that would work with drum/drum brakes and the correct bore size. (haven't got that far yet)
This is on my 52 2t dump truck, it's brakes need a complete overhaul anyway.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bryan Barratt, there is no problem doing what you suggest, you seem to have a good handle on the cautions involved, hope that helps. | | | | | Joined: Nov 2011 Posts: 3 New Guy | | New Guy Joined: Nov 2011 Posts: 3 | I installed a hydroboost on my 41 one ton and since I've gotten the bugs worked out: It works greaaaaaaaaaaaaaaaaat! And it looks allot better than the vacume diaphragm. | | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | I've started thinking about hydroboost. Power steering might be nice too. | | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | The problem will be in finding a dual reservoir master cylinder with a bore big enough to displace sufficient fluid to apply those BIG drum brake wheel cylinders. I believe the rear axle has brakes with two wheel cylinders per drum, doesn't it? The Hydrovac has a large, long stroke cylinder that moves a LOT of fluid, and the fluid from the master cylinder at the pedal just acts as a pilot signal to trigger the Hydrovac. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think a hydro boost is a great idea. However I think you'll find that a master cylinder well sized to your wheel cylinders will come from a say late 70's and 80's medium duty truck and the hydroboost that comes with that is a larger version than you probably want/need. Those larger Bendix "Hydromax" I think they're called have electric pumps for backup if the engine were to stall/die. I've had a truck with one and driven a few more, they sure work but not as refined and smooth feeling as the common hydroboost that you find in pickup sized trucks.
I would sure consider hydroboost even without power steering. I have both on my 2 ton and it's great. But for my 1 ton I plan to run just a small PS pump, a TC pump I think is the model, to operate the hydroboost and keep the manual steering. | | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | My truck has single rear wheel cylinders. The spare later rear i have has dual cylinders. I need to find all these cylinder sizes. Seems some old catalog digging is in order.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Does your truck have the original rear end in it? What size brakes does it have?
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I might be able to get you the displacement of your 'vac if you give me the model number.
That way you know what to look for. | | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | It has the original rear as far as I can tell. I'll have to crawl under it tomorrow for sizes and numbers. The vac is pretty rusty, so not sure if I'll find numbers, but thanks. | | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | So, the fronts are 14x2ish? The rears look like 15x3, with single wheel cylinders.
The Vac I could not find any numbers on, but the cylinder portion looked like 1.25 od? | | |
