7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, 1 invisible),
67
Mod | | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | i am looking for dual master cyl. for a 1954 chevy 1/2 ton pickup with drum brakes ft. and rear mounted in original spot. any one know a good one to use? let me know .thanks keith | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | look at CPP, I got mine from there for disc brakes front and drum rear. I know that they have all kinds of different P. valves to go with them not to mention vacuum assist or no assist.
Chris | | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | did the brake lines come out on the right side did it go together good? THANKS keith | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I have not yet put it in since i am working on painting under the cab. I will be posting pictures of it mocked up. Sorry! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used one from a mid '70s C10 with drums on my '56. It should work as well on a '54. They use the same brakes.
| | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | did the mid 70s bolt up the same as 1954 under the floor? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need an adapter bracket to bolt it up. | | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | where did you get the bracket from? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I got it from CPP. It is offered by most of the specialty vendors. Here is a write-up about the conversion on my '56. It is different from the '54 but it should give you the general idea. | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Hi Keith I have upgraded the MC to a dual reservoir, I went on the raybestos site and found what I was looking for that was for brake drums all around, here is the link for a 67 Camaro, http://www.raybestosbrakes.com/magnoliaPublic/home/catalog/product.html?partNumber=MC36233I had to make a bracket to mount it and make up new lines etc. Maybe this will give you some ideas
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | I did the dual reservoir update, it was a four day process. Thanks to the "mechanic" that said, "We dont need to bench bleed it, we can just bleed it after it's on..." Well after three days of not getting any fluid to the back brakes I finally just took it off the truck and bench bled it. "Amazing!", he said. All's fine now. I used Classic Parts for the updated parts. Mount kit #71-984 $89.95 and #71-201 master cylinder $54.95. You will have to enlarge/move the hole in the floor to fill/check the new reservoir or fashion another remote way to deal with it. Barring not bench bleeding the first time, it only took me about 3 hours to take stock stuff off and replace with new stuff.
