0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1064848 10/27/2014 8:05 PM
i am looking for dual master cyl.
for a 1954 chevy 1/2 ton pickup
with drum brakes ft. and rear
mounted in original spot.
any one know a good one to use?
let me know .thanks keith
look at CPP, I got mine from there for disc brakes front and drum rear. I know that they have all kinds of different P. valves to go with them not to mention vacuum assist or no assist.
Chris
did the brake lines come out on the right side
did it go together good?
THANKS keith
I have not yet put it in since i am working on painting under the cab. I will be posting pictures of it mocked up. Sorry!
I used one from a mid '70s C10 with drums on my '56. It should work as well on a '54.
They use the same brakes.
did the mid 70s bolt up the same as 1954
under the floor?
You need an adapter bracket to bolt it up.
where did you get the bracket from?
I got it from CPP. It is offered by most of the specialty vendors.
Here is a write-up about the conversion on my '56. It is different from the '54 but it should give you the general idea.
Hi Keith
I have upgraded the MC to a dual reservoir, I went on the raybestos site and found what I was looking for that was for brake drums all around, here is the link for a 67 Camaro,
http://www.raybestosbrakes.com/magnoliaPublic/home/catalog/product.html?partNumber=MC36233
I had to make a bracket to mount it and make up new lines etc. Maybe this will give you some ideas
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
I did the dual reservoir update, it was a four day process. Thanks to the "mechanic" that said, "We dont need to bench bleed it, we can just bleed it after it's on..." Well after three days of not getting any fluid to the back brakes I finally just took it off the truck and bench bled it. "Amazing!", he said. All's fine now.
I used Classic Parts for the updated parts. Mount kit #71-984 $89.95 and #71-201 master cylinder $54.95.
You will have to enlarge/move the hole in the floor to fill/check the new reservoir or fashion another remote way to deal with it.
Barring not bench bleeding the first time, it only took me about 3 hours to take stock stuff off and replace with new stuff.
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
