7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel), 94 guests, and 3 robots.
Topics128,048
Posts1,055,663
#1064813 10/27/2014 3:32 PM
53 (235) - Just got running after 2 years. was leaking water around water pump gasket. Took off and cleaned pump, resealed and runs fine. Except there is a noise that it makes that makes me feel like I need to do something before I TOW home again. Any Ideas?
1946 1/2 ton - 1962 "261"
1953 1/2 ton 5-window - "235"
1955 1/2 ton - 55 "265" Corvette motor
1959 1/2 ton Fleetside - "283"
Time to replace the water pump or take yours off and have it rebuilt. You can find kits to rebuild it yourself but it takes a good press and time. Not a real easy home project.
If you buy a replacement, make sure it is a 1953-1955st pump. A thinner fan belt (3/8") was used in those years.
Who has them?
ARDONE SELECT Part # 5511510 New
with 3/8" Grooved Press on Pulley
Part Image
$80.79
rockauto.com
