1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | 53 (235) - Just got running after 2 years. was leaking water around water pump gasket. Took off and cleaned pump, resealed and runs fine. Except there is a noise that it makes that makes me feel like I need to do something before I TOW home again. Any Ideas?
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Time to replace the water pump or take yours off and have it rebuilt. You can find kits to rebuild it yourself but it takes a good press and time. Not a real easy home project. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you buy a replacement, make sure it is a 1953-1955st pump. A thinner fan belt (3/8") was used in those years.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | ARDONE SELECT Part # 5511510 New with 3/8" Grooved Press on Pulley Part Image $80.79
rockauto.com | | |
