| | | Forums66 Topics128,035 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | Drove my 53 (235) in town yesterday. on the way home, noticed not driving right, hesitation. Then it just quit and I coasted into a driveway. Noticed no fuel in fuel filter (in line before carb). Would fire with starter fluid and then quit, not getting fuel. Towed home and took off fuel pump. Took top off pump but could not figure out anything by looking. If I push in the lever should I feel/hear anyting (air) coming out? Bad thing about the whole thing - While sitting waiting for AAA, a 40 Ford PU drove by and honked at me. OUCH!
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Should feel suction on tank side when lever actuated. Sucks gas from tank and pushes to carb. Check lines from tank aren't blocked before replacing pump. Many guys put an in line filter at the tank to catch sediment.
Ed
| | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | I went thru a few pumps this short summer. I was using the Airtex 4149 one. One gave out completely another one would not return the pump arm back out fully and another would pump but had almost no pressure behind it. The one with little pressure could not even exert its self if you just rest your finger over the out port. It would pass air if you took you finger off. If i may recommend switching to a carter pump as i have not found a single person have issues with one as of yet. | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | I took off the line coming from the tank that goes into the fuel pump, gas was flowing, had to plug. line on the other side of the pump is clear all the way to the new inline filter. I think Carter may be the answer.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The fuel pump gasket is asymmetrical. It would be (should be) obvious if you put the pump on up-side down - the gasket would either not be mated correctly with the block or not be mated correctly with the pump. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it had been upside down it wouldn't have been running to start with  that's a common aftermarket pump, doesn't matter who made it, just needs to work - did you try working the arm as Ed suggested? if you don't hear/feel any action, get a new pump at your FLAPS Bill | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | Don't hear any action, will order new one. Carter M751?
| | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Carter M2118. That is the number i was told to get.
| | | | | Joined: May 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 27 | For what it's worth,I had the same problem last year- went through several pumps and they would fail after a few months. I ended up replacing the mechanical pump with an electric one- no problems since. Also I added a fuel filter before the pump, then another clear one just before the carb (primarily so I could monitor fuel flow).
Bluesharp- If you don't blow you suck....
'50 Chevy 3600 "Ernest"
| | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | There is an inline filter before the pump and one before the carb.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | You may have a chunk drifting around in the tank which intermittently falls on the top of the pipe in the bottom of the tank. Happened to me. There is supposed to be a screen sock on it, but sometimes they are missing. Carl
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Happened to me once as well. Try disconnecting the fuel line somewhere between the pump and the tank and blow some compressed air towards the tank. make sure to remove the gas cap. This will clear the junk back out of the fuel line area of the tank, and let the fuel flow untill the junk chokes it off again. If the engine will run after doing this, it means you need to clean out the tank.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Happened to me about 87 times bringing my newly purchased 52 home many years ago.
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | When it happened to me, I was still very new to the game. I replaced a lot of stuff before solving the problem. I remember laying out on the street and draining my gas tas tank. It turned out to be wood slivers that had become soaked in gas and would sink to the bottom. After I pulled them out, the truck ran great.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | Gas is flowing from line from tank, had to plug.
Order new pump from Rock Auto
Carter M2118
