| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | i have put disc brakes on my1964 3/4 ton pu from a 1985 burb 3/4 ton 8 lug.im looking for part number for tie rod ends. i heard cpp , and 456 have them. no luck. the 85 burb ends are to long.i know this is nothing new to do any help would be appreciated art | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy art444, maybe I'm missing something but I don't see enough information here to be able to help you, if the 85 ends are too long then are you looking for p/ns for 64 ends? | | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | 3b the 64 tie rod is to big to fit in 85 spindles i have stock numbers for 64 and 85 . i know this has bin done before but i missed the part about the tie rod ends. thks art | | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | well i got this info off stovebolt site. tie rod ends moog es409rt,es409lt .adjuster sleeves es2004. but will inner 1964 tie rods screw into these sleeves in the right direction? art | | |
