| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | pulled a lifter off my 235 and measured it.....and......its 1" dia.!
has anyone seen lifters this size in a 235 before - or anywhere come to that!
any suggestions where i could buy a set of 1" solid lifters ?
or is my only option to get some custom made?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What diameter is the hole for the lifter?
What diameter do you think was used originally?
~ .990"?
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Stock lifter size for the Stovebolts is .990". Sourcing new ones for the last few years has been difficult according to Patrick's. Not many modern engines use a lifter that large, so there isn't much crossover interchange unfortunately.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is very common to reface lifters. Solid lifters come up on eBay regularly.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | oh i thought they used 0.845" lifters..... ...i must have got that from somewhere.....
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | The Chevy 6 cylinders didn't use that size until the later 194-292 series of engines.
