| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Next week I'm bringing a 41 4 door deluxe sedan home all original great car everthing works the clock,radio and the vac wipers and best of all NO rust holes anywhere.My question is will a 235 out of a 54 chevy pickup take the bell housing and flywheel from the 41?I have a rebuilt 235 here and rather than rebuild the 216 thats in it I'd like to swap out the engines and keep the 216 for the future.It even has the vac shifting and that works.
Pete
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Pete52, as far as I know everything peculiar to the car from the 216 should swap over to the 54 truck engine. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You will need to get a water pump plate from Dave. You also may have to tweak the accelerator linkage. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1954 truck 235 block uses the same style/location water pump as was used in 1941 car/truck 216 engines. The pulley on the 1954 water would have a groove for a narrower fan belt than was used in 1941.
No water pump relocation plate is needed.
The 1941 clutch housing would need to be used, and you might as well use the 1941 clutch assembly and flywheel (but, the 1954 clutch assembly and flywheel could be used). The 1954 clutch housing will not bolt up correctly on a 1941 frame
My 1954 blocks have a threaded hole for the 1954 accelerator linkage bell-crank and a threaded hole in the location used for an earlier bell crank (I do not know if that second location is the same as used in 1941).
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks,this winter,in my new garage I'll swap them and keep the 216 until I get a chance to rebuild it and put it back in.
Pete | | |
