| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Is there a true bolt on dual master cylinder or power brake setup that DOES NOT require one to remove and replace the cross member? I am looking for a good way to improve the brakes without cutting up the original components. I am currently running drum/drum. Would either like to do a minimum of dual master cylinder or go for the power brake set up. Thanks in advance. Steve | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I ordered my dual MC setup from Brothers. Its a CPP kit and if you dont use a power booster there is no modifications to anything. You can find pics in More pics in the Bolt Bucket below my signature. Dads50 has a very similar setup as well. His runs and drives. Mine is still in the frame-up process. | | |
