Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 95 guests, and 0 robots.
Topics128,274
Posts1,058,433
Members48,490
#1064141 10/23/2014 10:23 PM
Is there a true bolt on dual master cylinder or power brake setup that DOES NOT require one to remove and replace the cross member? I am looking for a good way to improve the brakes without cutting up the original components. I am currently running drum/drum. Would either like to do a minimum of dual master cylinder or go for the power brake set up. Thanks in advance. Steve
smoloney #1064324 10/24/2014 11:15 PM
Gas Pumper
Gas Pumper
I ordered my dual MC setup from Brothers. Its a CPP kit and if you dont use a power booster there is no modifications to anything. You can find pics in More pics in the Bolt Bucket below my signature. Dads50 has a very similar setup as well. His runs and drives. Mine is still in the frame-up process.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
