0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | I need to know the fastener size of the "clutch head" screws used on the '51 AD bed to mount the fenders. Are any body washers used? My old bed has a combination of mismatched fasteners in this area. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Chevy Duty sells the proper bolts for about 49c each. I believe you need 18, so 9 bucks for original looking bolts.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Thanks but I don't want to use the original clutch heads. I need to know the exact diameter and length of the original bolts, so I can replace them with button head stainless allen screws. | | | | | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | 5/16" X 3/4", Stainless steel. No washers on the inside of the bed, Use fender washers on the fender side, then a lock washer and the nut. | | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | Silly question time: Why are these bolts called "clutch head"? They look like large Philips head bolts on my '51 and are a [censored] to remove. What's the trick? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Cluth head bolts were introduced when GM first upgraded to robotics on their assembly assembly line. I call them them clutch heads because the only way to get most of them off now days is to clutch the head with vise grips & crank on the nut with a wrench. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They are called clutch heads because they don't need downward pressure from the driver tip to screw them in- the driver doesn't jump when torque is applied, it "clutches" the screw. You need downward pressure to Phillips, slotted, and Filister. You don't for Torx, Robertson (square), hex/allen, and clutch. Clutch heads can stand a lot of torque without ripping out the slot.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | 4ontheFloor - I appreciate the explanation. Is there a special screw driver required (or available) specifically for clutch heads? The bolts on my truck have a large Phillips-looking head which strip out easily with even my largest screw driver. What kind of a slot does a clutch head have? I think I like sixpack's idea of using similar Allen head bolts to replace the original hardware when it all goes back together. | | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | The size clutch head driver you need is a 5/16
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I know I sound like a Chevy Duty commercial but I bought a set of clutchhead screwdrivers from them for $14.95 All the truck's sizes are represented.
With the proper tool they really are not bad.
| | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | | | |
