2 members (Woodcmiami, Bill Hanlon), 100 guests, and 4 robots.
Topics128,113
Posts1,056,279
Members48,439
#1063479 10/20/2014 9:54 PM
58 deluxe heater. My radiator guy says not fixable. I want to keep the original heater setup, so I need a replacement core. Does anyone offer a replacement? Radiator man says he can attach my top and bottom to a core that is the right size. Thanks
not reproduced, but it's been said here the heater core from a 72 Ford pinto w/ AC fits the TF dlx heater .... I'd say take the man up on the re-core, it's the best choice
My problem is that I have to find the core. Are the cores for the recirculating heaters the same size?
Is the TF dlx heater for 1958 the same for the full size car with the dlx heater?
Last edited by cletis; 10/21/2014 6:34 PM. Reason: deleted personal message, part offer
1970 VW Beetle
ahh, the shop isn't saying they can repair yours .... unless you find a replacement core grin
no, the cores for the different style heaters are different, and the car and truck heaters were different 55-59, you might need to investigate the Ford core
Hey Tim,
You can get the core from the brass works co. It is expensive if you want to go that route. I got creative with mine like Red 58 suggested and I did some research after Red gave me the exact dimensions for the core. I had nothing to start from but some configuration someone had made from some copper tubing. The only core I could find over the counter was for a 71 Ford Pinto with air. The dimensions are close but you have to do some fabrication to attach the core to the heater box with a few pop rivets. The core is all aluminum. The inlet and outlet on the core with air is at 3 and 9 on the clock. The core without air has the inlet and outlet at 12 and 6 on the clock. It will take some tinkering and measuring but it can be make to work. The Pinto core cost me around $26.00 and I used some scrap sheet metal to make the brackets. I'm not worried about being original all I wanted was to be warm while driving. It's like Red said . Don't expect to feel like you are in the living room with the old wood stove roaring but it will be adequate to enjoy the drive in your long sleeves.
Oh and by the way my truck is a 58 apache with the 235 and overdrive. Might not look like much to others but it's mine and it takes me anywhere I want to go whenever without hesitation.
1 Offline
You may check over at Classic Parts. They were advertising a A D Heater core a few years ago.
Is a AD core going to be the same as a 1958 ????
1951 3100 Chevrolet
AD cores won't work for the 58 deluxe heater
That's what I thought Bill !!
Tim
1951 3100 Chevrolet
