4 members (3B, MickeyP, 1955 1 Series, 1 invisible), 47 guests, and 3 robots.
Topics128,012
Posts1,055,321
Members48,419
#106411 04/08/2002 2:59 PM
I need to know the fastener size of the "clutch head" screws used on the '51 AD bed to mount the fenders. Are any body washers used? My old bed has a combination of mismatched fasteners in this area.
#106412 04/08/2002 3:48 PM
Chevy Duty sells the proper bolts for about 49c each. I believe you need 18, so 9 bucks for original looking bolts.
54 3100 with 235
62 flatbed dump C60 with 261
#106413 04/08/2002 4:16 PM
Thanks but I don't want to use the original clutch heads. I need to know the exact diameter and length of the original bolts, so I can replace them with button head stainless allen screws.
#106414 04/09/2002 12:01 AM
5/16" X 3/4", Stainless steel. No washers on the inside of the bed, Use fender washers on the fender side, then a lock washer and the nut.
#106415 04/09/2002 2:59 AM
Silly question time: Why are these bolts called "clutch head"? They look like large Philips head bolts on my '51 and are a [censored] to remove. What's the trick?
#106416 04/09/2002 6:54 AM
Anonymous
Unregistered
Anonymous
Unregistered
Cluth head bolts were introduced when GM first upgraded to robotics on their assembly assembly line.
I call them them clutch heads because the only way to get most of them off now days is to clutch the head with vise grips & crank on the nut with a wrench.
#106417 04/10/2002 12:30 AM
They are called clutch heads because they don't need downward pressure from the driver tip to screw them in- the driver doesn't jump when torque is applied, it "clutches" the screw. You need downward pressure to Phillips, slotted, and Filister. You don't for Torx, Robertson (square), hex/allen, and clutch. Clutch heads can stand a lot of torque without ripping out the slot.
Paint & Body Shop moderator
#106418 04/10/2002 1:45 AM
4ontheFloor - I appreciate the explanation. Is there a special screw driver required (or available) specifically for clutch heads? The bolts on my truck have a large Phillips-looking head which strip out easily with even my largest screw driver. What kind of a slot does a clutch head have? I think I like sixpack's idea of using similar Allen head bolts to replace the original hardware when it all goes back together.
#106419 04/10/2002 2:19 PM
The size clutch head driver you need is a 5/16
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
#106420 04/10/2002 5:19 PM
I know I sound like a Chevy Duty commercial but I bought a set of clutchhead screwdrivers from them for $14.95 All the truck's sizes are represented.
With the proper tool they really are not bad.
54 3100 with 235
#106421 04/11/2002 6:44 AM
Thank you.
