10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 35 | was reading MarkT's dual carb question, got one of my own...
I have a Nicson dual intake for my GMC 270... It appears as though the base-bolt pattern of the intake studs to attach the carbs to the manifold DO NOT match my Rochester carbs??
Are the carburetor base patterns different on the Carter, Rochester, Zenith carbs??? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, there were different bolt spacings on early and late Chevy sixes and possibly GMC too. Also different throttle shaft orientations among the GMC engines. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Take a look at the thread title "Zenith physical carburetor sizes".
Reference is made to S.A.E. sizes.
There are other threads stating the S.A.E. sizes on Carter and Rochester.
Basically size 2 is 2 11/16 center to center; and size 3 is 2 and 15/16 center to center.
The above is true for Carter, Holley, Rochester, Stromberg, and Zenith.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Nicson is indirectly giving you good advice: you want carburetors smaller than your Rochesters. | | | | | Joined: Aug 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 35 | Panic, carbking, cletis... Really wanna make a go of the dual Nicson! What smaller carb do y'all recommend? | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | There are many different carbs that may be used successfully. Your choice should depend on, in order: (1) The amount and scope of engine modifications (2) Your expertise with the carburetors of your choice (3) Your budget These articles may help you: http://www.thecarburetorshop.com/Dual1barrelcarbs.htmhttp://www.thecarburetorshop.com/Triple1barrels.htmPersonally, if it were mine, I would use Zeniths from either a G.M.C. 228 or G.M.C. 248, depending on the scope of engine modifications. I like to make my changes appear as if they COULD have been factory; and the Zeniths were original on the G.M.C. A detriment from your standpoint to using the Zeniths is that they are probably the high end cost-wise to what is available. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
