7 members (rick46ia, delky, Samantha, Hotrod Lincoln, crenwelge, Bill Hanlon, 1 invisible),
118
Mod | | | Forums66 Topics128,261 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have a 1965 348 rebuilt engine in a 1957 Chevy 3/4 to truck (NAPCO). I installed a CenterForce Clutch and pressure plate appropriate for the engine. I also have the long throwout bearing. The clutch fork is the cast type. The problem is that the transmission will not go into gear (engine running). It appears the clutch is not engaging all the way. All the measurements and fork angle seem correct according to the CenterForce spec. sheet. When I try to compensate the fork linkage to get increase throw-out bearing travel, I either break or lose the pivot pin holding the fork to the pivot ball. Measuring, the Centerforce assembly is about an inch shorter that the stock one that is on my 283 which was originally in the truck and worked fine. I'm wondering if the Centerforce pressure plate/clutch assembly is just wrong for the truck application (bell-housing and forged fork). Any opinions before I do another un-install would be much appreciated. Thanks, don | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | It may be the throught out bearing. You may need the short depending on which pressure plate you have. Some have taller finger on the pressure plate which translates to needing short bearing.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree about the TO brg. Generally the newer style clutches use the short brg. Can you contact Center force & get there thoughts on it. If it has the "Beehive" type pressure plate were the fingers protrude out to the outer edge of the pressure plate, you need the short brg. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If it won't go into to gear while the engine is running, sounds like the clutch is not releasing from the flywheel/pressure plate.
One problem may be the disc is in backwards.
Do the gears grind when you try to put it into gear with the engine running? If so, then the clutch is not being released. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | What you guys are saying is the opposite of where I was going. But upon reflection it makes absolute sense. The gears do grind with the engine running. I think I need to try the shorter throw-out bearing as suggested. Thanks for the insight. I'll let you know how it works out. don | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Sounds like the clutch is simply out of adjustment. Remove the free play in the clutch by adjusting the 2 1/2 inch nuts on the d- shaped rod.
Generally the clutches come with the proper throwout bearing when they are sold as a kit.
I am unfamiliar with center force clutches. Are they a "borg and beck" type, or a diaphragm type. I have a 12 inch diaphragm clutch in my 59 jimmy. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I am not an expert on CenterForce clutches (or any). I have tried adjusting and even making different length "D" rods. Two things: - I did not get the throw-out bearing as part of the clutch kit, however they do offer a short and long one. - The install is in a 1957 truck with a 1965 348 using the same bell-housing as the 283 I removed.
The CenterForce tech support wasn't much help, apparently the bell housing is too old to be on their "supported list."
I didn't mention that when I try to start the engine, select a gear, clutch pedal depressed, it is still in gear. That leads me to the logic of the prior posts suggesting too the need for the shorter throw-out bearing. Thanks, don | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Don, are you using a Centerforce type I pressure plate or are you using a II or III? What year bellhousing are you using? If I remember your earlier posts you added side motor mounts when doing your engine install. I have included a link for an information sheet that Centerforce put out regarding GM clutch forks and through out bearings. http://www.centerforce.com/images/store/midway-industries-inc/CTF-CF165473-I93GM001.pdf | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Don: Thanks for the PDF. Since mine is a cast fork, I need the N1430 release bearing (as per the spec. sheet). I found the same release bearing at NAPA for less money.
Yes, the 348 is in (my progression has been 235, 261, and 283 engines installed). Needless to say, I get a lot of feedback about making up my mind. (Now I'm wondering about a 409)
I will see what happens this weekend. don | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Once you get the 348 working good it will be a piece of cake to upgrade to the 409, minor differences such as dipstick location. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks for all the replies, as usual all good advice for determining what the problem could be. You all put me on the right track for looking at the problem logically. Ends up it was the throw-out bearing. The stock one was too long, I got the short one and I am back in business. Although I feel a bit dumb not diagnosing this problem properly myself, I did make some improvements (e.g., re-curved the Hurst shifter), during the multiple removals and installs of the transmission. Also, I am a lot better at transmission installs now. Thanks again, don | | |
