8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd),
138
Mod | | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Been having issues with my fuel tank. Looks like it was treated with Red Kote but it was a poor job. I tried using acetone to get the stuff out but that just made it worse. What can I use to get this gunk out or should I scrap it and go with a new one?
Thanks Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Is the tank under the seat or is it attached along the frame. If it is frame mounted, there are no reproductions so you will have to repair the one you have, fabricate a new one, or hunt for one that you can adapt. A seasoned radiator gas tank repair shop can clean out your old one and apply sealer. New under seat tanks are relatively inexpensive. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Under seat, Guess I'll go repro
| | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | I've had pretty good luck boiling them out overnight at an old time radiator shop. My guy strongly discourages any sealer afterwards. Says they all tend to fail sooner or later. His feeling is if you keep it full of gas it won't rust. Seems to work. | | |
