1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | I suppose you old tmers are thinking: Here we go again, another question on a VIN number. I have a '49 panel, VIN 6JPD8300. Using the "search" section on this forum I now know what the 6 means, what the D means and what 8300 means. Don''t know what JP means. Although titled as a 49, this panel has a 1950 flat, side cowl lever, not the knob like on previous years production. It also has conventional shocks and not the knee action ones. Any help on the JP would be appreciated. Jerry
1 1951 Chev Panel with a 350 small block, automatic tranny. 1 2004 Chev 2500 HD pickup... stock 1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 6= Oakland, J= 1951, P= series 3100, D= April That does NOT mean you have a 1951 1/2T panel, it just means that's what the numbers mean. Anything can happen with titles/old trucks. There are AD gurus on this site that can tell you by seeing pics of it. Look in our gallery to pick up subtle differences in years. A big one is vent window started in 51. BUT  doors can be switched. Check the motor serial to help verify.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Jerry, to decode vins see the tech tip vinbuster, it says you have a '51 1/2T - and for a lot of detail differences in the AD years see this tech tipas Bart points out, you have no idea what's been done to the truck over the last 60-some years, including if the title or ID tag was swapped from something else Bill | | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Thanks for the info Bill and Bart. I had previously reviewed the TechTips/AD Spotting Guide and determined that the tube shocks and flat paddle side cowl lever were not 1949. At that time I couldn't decifer the J or the P. The existing left side cowl vent is '47 through '50 and would rule out 1951 or later.
The right door is solid glass: '47 through '50. The left door has a vent, 1951 and up. It's logical that one of the doors has been replaced with one from another model.
The hood, side badging only says Chevrolet with no series number, i.e. 3100 That indicates '51 or '52.
I just completed draining the rear diff. so inspecting the pinion gear again will not happen soon.
No heater. All doors handles are rotate to unlatch.
The guage cluster needs to be r&r'd so I'll check for a date there.
Based on the existing graphics, it is lodgical the truck was made in Oakland. The truck was used by Tasty Bakery in Bishop,CA.
I'm not all that concerned about the correctness of the title. It's legal and that's all that really counts for now. But it is very interesting to do the research AND it adds to my growing knowledge of AD trucks and my panel.
Once again, thanks for the expert guidance it is very much appreciated for a newbie like me.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Great to have another AZ guy.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If you can post pictures of it,that would really make a difference as well.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Tim: I'll do my best to try and post some pic's. Jerry
