8 members (Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian, KEVINSKI), 162 guests, and 6 robots.
Topics128,075
Posts1,056,007
Members48,433
Looking for an original GM turn signal switch for my 63 suburban 4x4.
It seems that the aftermarket switch can't handle the wats and it overheats. The terminals then become distorted and short causing the lights to flash as if the truck had a hazard flasher
I trimmed the terminals and now the system works ok but I lost the connection that sends the signal to the dash ( right signal only ) that blinks so you know the turn signal is operating.
This is the second switch I have installed as the 1st one stopped working altogether.
Should I go with led lights to lower the wattage.
_________________________
is this the GMC? add-on type signals or factory? is there a fuse in the circuit? if you had 2 switches go bad in different ways it might be defective switches or as likely, the installation has some other problem
if the connections 'overheat' it's a poor connection, not an 'under-rated' switch .... watts = heat, there shouldn't be any watts in the switch terminals unless there's poor contact
Thanks Bill....it is an aftermarket GMC switch for my 63 gmc sub 4x4.
Back to the drawing board!
