2 members (ndkid275, ronsway),
168
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 3 New Guy | | New Guy Joined: Dec 2008 Posts: 3 | I have a 51 pick up with a 194 in it (casting # 3792858). I'm about to have the carb rebuilt but before doing this I wanted to make sure it would work well with my 194. The carb is a Rochester Monojet . When I ran the numbers off the carb (17057314) i cant find any info of it being mounted on a 194. Smallest block I found was 250. Do you guys think it'll be an issue pairing these up? Any info is appreciated and much thanks in advanced! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | ive never heard of a 194 in a 51 pickup. I think it will work OK. The mixture on a mono- jet can be tailored by adjusting the metering rod height.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | A Monojet makes a good fishing weight at the end of a trotline. It was a poorly-designed substitute for a good carburetor when it was new, and it hasn't improved with age.
One version of the MonoJet was used on the 140 cubic inch Vega engine, which would be jetted too rich for a 194 I-6. The carb calibrated for the 250 would run a little lean if it was used on the 194. Cross-reference the carb part number to see what its original application was to see if you need to jet it up or down. Jerry
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I always found the Rochester to work pretty well myself. My 230 has the 1 brl Rochester, about the only problem I've had is the choke stove and spring rusted out on the exhaust manifold that controlled the automatic choke... Bought one of those electronic replacements, so-so in working...
John | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | A Monojet makes a good fishing weight at the end of a trotline. It was a poorly-designed substitute for a good carburetor when it was new, and it hasn't improved with age.
Jerry Sorry Jerry, have to disagree about the trot line; it would scare the fish!  Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I worked on fleets with Mono-jets on 292 & 250 engines for many years. They worked out real good for me. The newer ones with the electric choke was the best. The older ones need to retain the matched manifold for the choke to work right. The manual choke models were best. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
