0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | 58 deluxe heater. My radiator guy says not fixable. I want to keep the original heater setup, so I need a replacement core. Does anyone offer a replacement? Radiator man says he can attach my top and bottom to a core that is the right size. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not reproduced, but it's been said here the heater core from a 72 Ford pinto w/ AC fits the TF dlx heater .... I'd say take the man up on the re-core, it's the best choice
Bill | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | My problem is that I have to find the core. Are the cores for the recirculating heaters the same size? | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Is the TF dlx heater for 1958 the same for the full size car with the dlx heater?
Last edited by cletis; 10/21/2014 6:34 PM. Reason: deleted personal message, part offer
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ahh, the shop isn't saying they can repair yours .... unless you find a replacement core no, the cores for the different style heaters are different, and the car and truck heaters were different 55-59, you might need to investigate the Ford core Bill | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | Hey Tim, You can get the core from the brass works co. It is expensive if you want to go that route. I got creative with mine like Red 58 suggested and I did some research after Red gave me the exact dimensions for the core. I had nothing to start from but some configuration someone had made from some copper tubing. The only core I could find over the counter was for a 71 Ford Pinto with air. The dimensions are close but you have to do some fabrication to attach the core to the heater box with a few pop rivets. The core is all aluminum. The inlet and outlet on the core with air is at 3 and 9 on the clock. The core without air has the inlet and outlet at 12 and 6 on the clock. It will take some tinkering and measuring but it can be make to work. The Pinto core cost me around $26.00 and I used some scrap sheet metal to make the brackets. I'm not worried about being original all I wanted was to be warm while driving. It's like Red said . Don't expect to feel like you are in the living room with the old wood stove roaring but it will be adequate to enjoy the drive in your long sleeves. Oh and by the way my truck is a 58 apache with the 235 and overdrive. Might not look like much to others but it's mine and it takes me anywhere I want to go whenever without hesitation. | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | You may check over at Classic Parts. They were advertising a A D Heater core a few years ago. Jerry
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Is a AD core going to be the same as a 1958 ???? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | AD cores won't work for the 58 deluxe heater
Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | That's what I thought Bill !!
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
