10 members (Gray_Ghost, Nick in Manitou, Gdads51, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, LAROKE, 2 invisible), 107 guests, and 3 robots.
Topics128,131
Posts1,056,372
Members48,441
#835840 03/16/2012 8:00 PM
Hi all!
Researching trailer hitches, on SB and other sites, haven't found much. Must I have a hitch custom-made? Have some stock steel available from the industrial bumper that was attached to the truck when we bought it.
Will move the spare tire up to the outer bedside, (already have some of that work done) to allow space for a hitch. Have the curved chrome rear bumper installed, no apron. Contemplating adding a rear apron at some point, but only if it wouldn't interfere with a hitch.
Wouldn't be using the hitch to do a lot of towing, just an occasional parade float or to employ this:
http://www.northerntool.com/shop/tools/product_200442143_200442143
Was hoping to find a hidden hitch of sorts, with the square connection device and a pin(?) necessary when the hitch is actually being used. (no ball visible or in the way.)
As usual, many thanks in advance for the terrific advice you all graciously share here!
I installed a hitch on my 59. Link is below. I contacted Curt hitch by E-mail on there site. They emailed me back very quickly and sent me specs. They hooked me up with a hitch. Try this first, They can make hitches as well.
Good luck
GrandPas truck,Nice. What specs did you provide them with. Frame width?
Frame channell depth? Width of mounting surface? Or? Sure looked fairly ez to mount.
Drew
SWEET! Thanks Grandpas Truck!
It was actually a snapshot of a truck my grandfather used in his nursery business that inspired me to buy Mabel. Didn't find exactly the 1956 model in the photo, (had to be running and affordable!) so bought the 1950 instead. Close enough!
Thanks a lot!
michelle
Message sent
thanks for posting the thread I was needing a hicth on my 50 truck also
Are you going to use your old underneath spare tire mount? I may be interested in purchasing it.
Here is the reply I got when I asked which model would fit my 1950 half ton.......
Chuck, the best bet would be the adjustable class III hitch, part number 13701.
Thank You,
Brad Howell
Technical Support Representative
800-798-0813 Direct
608-237-2268 Fax
www.curtmfg.com
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Check into a motor home hitch. They have ones that are adjustable side to side. You may have to do some cutting and welding, if you want it to look good. Curt has one that mounts to the side of the frame rails, whereas Rees and Hidden Hitch mount to the bottom. I think mounting to the sides would give you a little more up and down adjustment.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
AbleBabel,
Check out tbrtengineering.com they have a hitch on the market now.
Originally Posted by jonmhelt
AbleBabel,
Beat me to it Jon. grin
More pix on Flickr.
I'm running a reciever hitch from tbrt engineering and I love it. When I'm not using the hitch I slide it into the reciever from the front, so it's hidden under the bed. I don't have a rear bumper but I do have my license plate on a spring loaded mount that hides the hitch and swings up when I need it.
Gas Pumper
Gas Pumper
Maybe something has changed, but I dont see that they offer a hitch that works with the stock bumper WITH provisions for the underbed spare tire carrier. Like this:
http://s160.photobucket.com/user/st...940_zps7259f6ac.jpg.html?sort=3&o=85
Lots more pics concerning this if you use the arrows. I wish something like this were available so use whatever you want to make that happen.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Gas Pumper
Gas Pumper
Now I see their drop hitch offering. Looks good! I do wonder how the underbed spare tire works with it. Since the whole tire pulls backward a considerable distance, you have to make sure to not just drop it down, but bring it out enough as well. I like their design.
Deve
The Think Tank
While I also like their design, I enjoyed building my own out of junk laying around. Cost me $4.28. (I had to buy longer bumper bracket bolts.) My receiver is well hidden, and I made the hitch in such a way that it can be slid further into the receiver to be unseen.
Carl
I have more zippers then a pair of cargo pants
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
