1 members (baldeagle),
53
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | kinda like solo's pepsi technique? guys at the jalopy site swear by this trick make sure ya use sulphered molasses like from a farm feed supply place. Bill | | | | | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | SWEET! (Sorry, I couldn't resist). 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
| | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | There is also, in the tech tips section, an artical about using your battery charger to make an electric rust remover.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yep ,, I've used both .
The molassis works fine but takes a loooong time .
The battery charger is Great , quick and clean . | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | you wonder how people figured this out. Maybe in this case they dropped a spoon in the barrel and when they finally got down to the spoon, it was clean, and that made em think. | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Gang Here's a Tech Tip from last year that was still in it's "transformation" process. I think we ran this as a feature one month ... it's there now, since you all were asking. Barry Week\'s Molasses Bath Hope this helps some. Peg
~ One of many.
