| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I'm planning on starting my tear down/restoration of my '53 this winter. Can I put the battery on a tender and forget it? Not sure how long it will take me, maybe 2-3 years if I'm lucky?
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Put a load on it periodically, like a headlight bulb, run it down about halfway, and recharge. Be sure to monitor the acid level at least once a month while it's on the charger, and add clean water (never acid) to keep the liquid above the top of the plates. Jerry
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Thanks Jerry...appreciate it!
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | "Full charge" specific gravity measured with a hydrometer is around 1.265. That's the best way to monitor the battery, by measuring the strength of the acid. Most parts stores will have a hydrometer in stock, or there's always a few of them on Ebay. They're very inexpensive, and there's no better way to check any battery with removable cell covers. Jerry
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | You can get battery monitoring chargers these days that shut themselves off when the battery is charged to prevent boiling one dry. How that would work over 2-3 years I don't know since I've never stored a battery that long. While I'm not a battery expert Jerry's advise on putting it through occasional discharge/charge cycles sounds like good advise to me.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Conventional batteries last an average of five years, with lots of good care. If your battery is two years old, you should count on buying a new one in three years. | | |
