10 members (Jay R, moparguy, walterhvogel, JW51, Jon G, Gray_Ghost, Stovebolt48, 55shaker, HelmutVonSchet, 1 invisible), 73 guests, and 0 robots.
Topics128,079
Posts1,055,941
Members48,430
#1062406 10/15/2014 1:18 PM
What center section can be swapped into my 1941 chevy 1/2 ton delivery trucks rear end to convert to open driveline?
Todd Touchberry
1955-62 Chev 1/2 ton, and some GMC's.
My Blog
You should make sure that you secure the spring perches if you install an open driveline.
G Online: Content
I've wanted to make the switch to an open driveline myself and have read that you need to reposition the spring perches. However, I've never been able to understand what is involved or why. I've looked at my truck (1953, 3100) and there isn't anything attached to the 3rd member that would be removed if I made the swap to a later open driveline model. My truck is not currently driveable (I bought it that way), so it leaves me unsure if something is missing or if I am simply not understanding the issue. Can someone please help me to understand what is actually impacted by the switch and why? Also, pics would be a huge help for me.
Thanks!
Mike
1953 3100
The Gray Ghost
My Project journal
You need to set the pinion angle on your replacement axle, then weld on spring perches to the axle. The perches from Classicparts have two holes to choose from to locate the axle. The off-center hole, placed to the rear of the axle tube will locate the axle close to the factory position.
G Online: Content
What if I am simply replacing the differential? I've read that you can use a late 50's-early 60's differential that will bolt into the existing axle housing. Do you still need to adjust the pinion angle? Is the angle that the axle currently sits at incorrect if you change the differential? Sorry to be so thick headed about this, just not experienced in it.
Mike
1953 3100
The Gray Ghost
My Project journal
The original axle housing has spring perches that allow the axle housing to rotate. The torque tube controls the rotation of the axle housing. Once you get rid of the torque tube, there is nothing to prevent the axle housing from rotating and changing the pinion angle. Therefore, you need to rigidly attach the axle housing to the springs at the correct angle.
Sput #1066886 11/06/2014 8:36 PM
That happens to be "changing the pinion angle" to the point of destroying the driveshaft- - - -about half a turn of the housing. The pivots have rubber bushings in them and they're a P I T A to weld.
