| | | Forums66 Topics128,078 Posts1,056,029 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | Since, if I understand this right, powder coating locks the frame in a plastic coating, how do you get a good ground? If part of the frame is not coated, will moisture work its way under the coating and lift it? I know there must be a pretty simple solution as there are alot of P/C frames out there.
| | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | normaly, just bolt the ground to it (it will scatch the coating enough to get a ground) if you are worried, wire brush or sand the area first.
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | It's not a plastic coating, so you don't have to worry about it lifting. I'm not sure of the chemical makeup of it, but the colored powder is baked on the metal and fuses to it. You will have to grind the small area that you want to run your ground to. You won't need an area larger than quarter, nothing to worry about. Cecil....... | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You need very good metal to metal contact for your main ground. If you don't have this, you will have never ending troubles. You could use a bolt that taps it's own threads as it is installed. This will bite into the metal and give you a ground. | | |
