| | | Forums66 Topics128,208 Posts1,057,448 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | Does anyone make the rear bolts and clamps for the 2nd and 3rd row? Does anyone have one that they will sell and I can make my own? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used carriage bolts in my '54. There were no clamps. There are bolt holes in the seat frame. What year truck are you referring to? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | "Re: 47-53 Suburban rear seat bolts and clamps" (in the title; but, not mentioned in the message-body) As Cletis posted, they were carriage bolts. They were not a high-domed carriage bolts, but they were not an elevator bolt. A regular carriage bolt (standard hardware) will work. A wing nut was used (standard hardware will work), and there was a special washer/clamp/spacer that was curved to fit the seat-frame-base tube. That washer/clamp/spacer had a flat surface on the top (these are not standard hardware). pictures (and a little text) are worth a thousand words (sorry about the blurry close-up focus) NOTE: no personal buying/selling should take place in this forum. Place a Want Ad in the Swap Meet (good luck - these are rare). Be sure you have your email address listed in your Profile. You might have to arrange for someone to send you a sample, so that you can fabricate the washer/clamp/spacer. You would then HAVE TO return the sample-part to the sender. | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Tim,
Is that the correct material for the block? Brass? I could easily makes those out of steel or aluminum. You wouldn't have actual dimensions of that block, would you?
Mark | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mark,
I do not know the material. Steel or aluminum would do fine. It is unpainted and unrusted metal. I do not think it is stainless steel, but that would work too. You would not want to paint it, because it would chip when the seats are removed/replaced (if they are/were replaced - that is why many seats are lost for/to posterity).
If I have not put that piece back in place (and, if I can easily find it), I take more photos and post them.
| | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | I think it is brass, that is what someone told me a while back. It would be very simple to make, that is why I wanted to see if I could find one. I will post in the want ads. | | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | Trod: The part you are looking for is 466123 Washer Special used starting in 1936 Suburbans and used up until probably 1955,perhaps later.I have six of them and will forward them to you if you would like them. (no charge) They are no use to me now as my 1939 Suburban is as finised as it will ever be. Stan Norrish (Ontario,Canada) [email protected] | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks for the part number and information, Stan.
If anyone want to obtain this part from Stan, please contact him via email or Private Message.
| | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | I will send Stan an email, as I found original seats and need the special washers. Thanks Tim. V/R, Nick | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I believe Trod was getting them. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | I have a machine shop at work and if they can make them, I will pass them on at cost if anyone needs them. Thanks to Stan. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I'd be interested in a full set,let me know how much they will cost via a PM message.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | I am not worried about the machining because it is free. I just don't know what brass is going to cost. I will have them get me a price on Monday. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Are they brass or are they aluminum? These may fit many years, up to 1966 Chevrolet. Count me in too. | | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | Trod, Sorry, I didn't try to take what was promised to you from Stan; just expressing interest like others. I need a full set too. Thanks Trod, Stan, et. al. V/R, Nick | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | How are you progressing on the hold downs ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | I bought the material out of McMaster Carr. 12" of the brass was $27. It was 3/4" X 3/4" which is the exact size square they are supposed to be. I gave the material to a guy at work on Wednesday. He is going to see how many he can get out of the 12" piece. I will keep everyone posted. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jul 2012 Posts: 3 New Guy | | New Guy Joined: Jul 2012 Posts: 3 | Trod,
I would very much be intrested in purchasing a set from you as well.
Thanks! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2012 Posts: 82 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 82 | | | | | | Joined: Oct 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 24 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 24 | Excellent.. Nice, now I have to look for some. | | |
