5 members (78buckshot, ShopRag, stlcardinalsguy, Ponchogl, moparguy), 79 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
I had the cam break in my 216 in my '41 PU and decided to replace the engine with a 261. I also decided to go to a T5 tranny from an S-10. Of course, the original brake and clutch pedals have no place to mount. Any idea where to find a source for the brake/clutch/ master cylinder set up that would have mounting brackets? I may have to separate the pedals to work or mount correctly. Any help would be appreciated.
If I'm not mistaken you can bolt the 261 to your '41 bell housing.
But if you want to change the pedal set-up, I moved your question here. I'm sure someone here has done it.
It might but, I was told I need to get a '48 to '53 bellhousing so the T5 will bolt up and it will bolt to the cross member properly.
Someone sells the modified bellhousing you are looking for, I will try and find out, but someone will most likely come on here with the answer before I get back. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Check out Jim Carters part #REME570 this could be what you need.
1941 Chevy
Sorry for the delay answering. I have been traveling. I will check this out. Thanks for the response
Or use an adapter/ spacer plate withnthe original 41 bellhousing.
Thanks guys. I found the bell housing I was looking for in AR when I was there last week and visited a couple of restoration shops.
I still have the problem of mounting the clutch/brake pedals correctly. I may have to go to an under the dash after market set up. Not sure who carries these items with the best results for the swap.
We did an under floor mount of the clutch and brake, Vacuum assist. See pics in my photo bucket http://s1191.photobucket.com/user/MortgageLaw/library/1941%20Chevy%20Truck
Great pics MortgageLaw. A number of the shots will be helpful. Can you tell me where you got the brake/clutch assembly? Was it complete or did you have to fab anything. I did not keep the original tranny but changed to a T5 from a Sonoma. No place to mount anything on it. Thanks.
i replaced my 216 with a 235 and used my original bell housing and used the original brake/clutch pedals and kept the foot starter I also used a T-5 from an s-10
I just purchased a Jeep TJ clutch and brake assembly. I'm anxious to see how it works. I needed a hydraulic clutch for my application. The same may be able to be done on yours. Ford and GM both used hydraulic clutches on the T5.
They used a Wilwood setup on this truck.
http://www.customclassictrucks.com/...pickup_firewall_fabrication/viewall.html
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I got my TJ pedal setup Saturday.
I held it up in place and snapped this picture. I kind of like where the pedals are going to land. I may have to remove/move the bracket for the brake light switch for slightly more pedal. Other than that, they look like they belong there.
http://s1074.photobucket.com/user/w...amp;_suid=141316076428109782596448232839
"The Fake Truck"
you need to use the 41 bellhousing because it has the rear motor mounts on it
Hoozat,
Looks like you used an adapter plate. Did you make this or purchase it? Is it 1/2" thick? I also tried to see if you have any bolts in the side of the T5 to help hold the pedal assembly?
Looks pretty good in yours. Does this mount under the dash so they are hanging pedals?
The '48 to '53 bellhousing also has the rear motor mounts but a modern tranny will bolt right up to it. No adapter plate needed. I just need to shorten the front spline/shaft.
