1 members (klhansen),
90
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | I had the cam break in my 216 in my '41 PU and decided to replace the engine with a 261. I also decided to go to a T5 tranny from an S-10. Of course, the original brake and clutch pedals have no place to mount. Any idea where to find a source for the brake/clutch/ master cylinder set up that would have mounting brackets? I may have to separate the pedals to work or mount correctly. Any help would be appreciated. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If I'm not mistaken you can bolt the 261 to your '41 bell housing.
But if you want to change the pedal set-up, I moved your question here. I'm sure someone here has done it. | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | It might but, I was told I need to get a '48 to '53 bellhousing so the T5 will bolt up and it will bolt to the cross member properly. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Someone sells the modified bellhousing you are looking for, I will try and find out, but someone will most likely come on here with the answer before I get back. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Check out Jim Carters part #REME570 this could be what you need. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | Sorry for the delay answering. I have been traveling. I will check this out. Thanks for the response | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Or use an adapter/ spacer plate withnthe original 41 bellhousing. | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | Thanks guys. I found the bell housing I was looking for in AR when I was there last week and visited a couple of restoration shops. I still have the problem of mounting the clutch/brake pedals correctly. I may have to go to an under the dash after market set up. Not sure who carries these items with the best results for the swap. | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | Great pics MortgageLaw. A number of the shots will be helpful. Can you tell me where you got the brake/clutch assembly? Was it complete or did you have to fab anything. I did not keep the original tranny but changed to a T5 from a Sonoma. No place to mount anything on it. Thanks. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i replaced my 216 with a 235 and used my original bell housing and used the original brake/clutch pedals and kept the foot starter I also used a T-5 from an s-10
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I just purchased a Jeep TJ clutch and brake assembly. I'm anxious to see how it works. I needed a hydraulic clutch for my application. The same may be able to be done on yours. Ford and GM both used hydraulic clutches on the T5. They used a Wilwood setup on this truck. http://www.customclassictrucks.com/...pickup_firewall_fabrication/viewall.html
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I got my TJ pedal setup Saturday. I held it up in place and snapped this picture. I kind of like where the pedals are going to land. I may have to remove/move the bracket for the brake light switch for slightly more pedal. Other than that, they look like they belong there. http://s1074.photobucket.com/user/w...amp;_suid=141316076428109782596448232839 | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | you need to use the 41 bellhousing because it has the rear motor mounts on it | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | Hoozat, Looks like you used an adapter plate. Did you make this or purchase it? Is it 1/2" thick? I also tried to see if you have any bolts in the side of the T5 to help hold the pedal assembly? | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | Looks pretty good in yours. Does this mount under the dash so they are hanging pedals? | | | | | Joined: May 2010 Posts: 8 New Guy | | New Guy Joined: May 2010 Posts: 8 | The '48 to '53 bellhousing also has the rear motor mounts but a modern tranny will bolt right up to it. No adapter plate needed. I just need to shorten the front spline/shaft. | | |
