2 members (Cletus1950, Gdads51),
114
Mod | | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 9 New Guy | | New Guy Joined: Oct 2014 Posts: 9 | I'm new to this website here and I have recently purchased a a 1952 Chevy 1300 and I can't seem to figure out what engine is in my truck. I have done my research online and I can't seem to fine any matches to the numbers I found. I have the numbers from the block behind the distributer and the number that was casted into the block and I can't seem to find any matches. So the number behind the distributer was c615014. The number that was casted into the block was 3835614. Any imformation on what enginet his is woul be greatly appreciated. I have attached images of the numbers I looked at on the block. According to my research these are the numbers to go by. I will add this is a Canadian truck.
Brandon
| | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | I would try a search for a 52 chevy 3100 instead of a 1300. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Is there any chance that number would be 3835814? What is the casting number on the head? | | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Pics didn't work, maybe try it again. Can you find a head casting number?
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Oct 2014 Posts: 9 New Guy | | New Guy Joined: Oct 2014 Posts: 9 | [quote=truckernix]Is there any chance that number would be 3835814? What is the casting number on the head?[/quote] [quote=Southtowns27]Pics didn't work, maybe try it again. Can you find a head casting number?[/quote] I can't figure out how to post pictures but the number on the block is definitely 3835614 you can clearly see the difference between the 8 and the 6 and the casting number on the head is 3695451 | | | | | Joined: Oct 2014 Posts: 9 New Guy | | New Guy Joined: Oct 2014 Posts: 9 | [quote=truckernix]Is there any chance that number would be 3835814? What is the casting number on the head?[/quote] [quote=Southtowns27]Pics didn't work, maybe try it again. Can you find a head casting number?[/quote] My bad part of the 8 was corroded away and even when I felt it it felt like a 6 and thanks to another forum I found the head number that matched it thanks for the help all | | |
