Hello All,
I'm looking to purchase a 302. The engine is several hundred miles from me so I can only check pictures of it. I need help with a block number. The block and intake manifold have the number 2194009. Also the engine has a air compressor attached on the passenger front.The engine has a huge generator on the driver side. I really want to find a 302. But, I'd really like to findout more about this engine (which runs good)before I make the drive. Thank you for the help
