BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,267 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jun 2014 Posts: 6 New Guy | New Guy Joined: Jun 2014 Posts: 6 | Hello All,
I'm looking to purchase a 302. The engine is several hundred miles from me so I can only check pictures of it. I need help with a block number. The block and intake manifold have the number 2194009. Also the engine has a air compressor attached on the passenger front.The engine has a huge generator on the driver side. I really want to find a 302. But, I'd really like to findout more about this engine (which runs good)before I make the drive. Thank you for the help
| | | | Joined: Jun 2014 Posts: 6 New Guy | New Guy Joined: Jun 2014 Posts: 6 | There is a great deal of info on this forum about casting numbers, etc. I'm struggling because I can't find the number 2194009 in any of the information. Could the guy have misread it? Any help would be appreciated. Thanks | | | | Joined: May 2001 Posts: 7,440 Extreme Gabster | Extreme Gabster Joined: May 2001 Posts: 7,440 | A 302 should have 302 stamped on the serial number pad. I think he misread the casting number by a bunch. Inliners International's casting number chart lists a 2193980 and a 2192402 for 302s. | | | | Joined: Oct 2014 Posts: 2 New Guy | New Guy Joined: Oct 2014 Posts: 2 | My 302 engine has the intake casting # 2194009 and block casting # of 2198980 which makes it a 302 from 52 to 54. By the way, I am looking for an intake manifold for my engine. Any leads? | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | My 302 engine has the intake casting # 2194009 and block casting # of 2198980 which makes it a 302 from 52 to 54. By the way, I am looking for an intake manifold for my engine. Any leads? Post a Want Ad in the Swap Meet | | |
