1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | I know this question has been asked to many times to count, but even with all the information on hand I am still in the dark. The block number is 3769716 which tells me it is a 1958-62 235 engine, the number by the distributer is F0925A that is the part I am having trouble with. I know the F stands for the Flint Plant and the 09 should be the month but what is the rest?????? I would like to install the right spark plugs it had AC R46 Acniters in it. Is this a car or truck engine??? Thanks for your help!!!
Marv.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | There is a date code cast into every block and head. On Dist side near starter. first is a letter A-Jan, B-Feb etc. then number for day of the month and lastly single number for year ie. 9 for 1959 etc. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | F0925A; F is Flint plant, 0925 would be September 25th assembly date, A is Passenger car 235 with manual transmission. As noted in the previous post, there will be a casting date near the starter.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Thanks!!! to all for your help.
Marv. | | |
