0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 173 Shop Shark | | Shop Shark Joined: May 2013 Posts: 173 | What would I have to do to install a 292 into my 1940 truck. Also I plan to put a T-5 trans from an S10 in it too | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | The '37 is very similar to your '40 and the 250 is very close to the 292, so like mine, you will have length issues. I cut the firewall and moved the engine back plus moved the radiator forward. I could have left both if I wanted to run electric fan and have the engine setting right on the firewall. You will also run into the water pump issue, your 292 water pump will set much lower on the engine then the 216 did making the fan blades hit the lower radiator inlet if you run a mechanical fan. I lowered my radiator as well as moved it forward. You will have to make your own side motor mounts and brake and clutch linkage. Doesn't the factory pedals mount to the trans? The 292 probably will not clear the cut out in the firewall, its a fairly tall engine so some test fitting will be in order.
Trans should hook right up to the engine along with custom made crossmember and mount. New driveshaft, and later model rear axle for sure. That leaves you with drum front brakes with 6 lugs, and some bolt pattern for the rear? I run a '79 Trans Am 10 bolt rear axle, with '73-'79 GM disk brakes up front, both with 5 on 4 3/4" bolt circle.
You will also have to adapt the park brake lever to the transmission or swap to a foot operated one custom mounted. Don't forget to switch over to 12 volts, thus making the fuel gauge not work with out a voltage reducer. The other gauges will work just fine. Steering will clear also.
Joe | | | | | Joined: May 2013 Posts: 173 Shop Shark | | Shop Shark Joined: May 2013 Posts: 173 | just checked out your truck and its very nice...well done! Also, what kind of gas mileage do you get with the 250 ci + 3.08?? | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | Not very good, I haven't checked it with my new dual W-1's yet, but it used to get around 16 with the single Mono-jet carburetor. When I hit the highway for a day of driving, its usually around 70 mph, so thats why the mileage is probably lower then it could be. I believe wind drag also plays a big roll in it. I got almost 20 on one trip, it was all on back roads at or below 55 mph.
I had a 3.42 gear for a while and with it, the truck was noticeably quick and more responsive, but the high rpm at 70 was terrible. My tires are a 235/75 R15 (28" tall). Right now at 70, the engine runs just below 2400rpm which is just right, to pull a hill, just give it gas, no down shifting needed.
Joe | | |
